Finding out the voltage range of an input card at runtime
MartinMcD
Hello there,
I have a large data acquisition application. When I create a voltage input channel to add to a task I use custom scales. Now, this means that the possible Min & Max value (in scaled units) will depend on the custom scale and on the input range of the card. I need to work out what I can set these two values to at runtime.
I can call the AI.Min property once the task timing has been set up, which is no use as by then I have potentially already generated an error.
Does any body know if there is a quick way of just checking what the input range of a device/channel is at run time, so I can work out what my scaled unit min & max values need to be?
Thank you,
Martin
post-13935-0-22686900-1317245696_thumb.p
