Serial port state
Break_da_funk
Hello!
How can I check a com port state: opened/closed by using Visa Serial components?
I found property: "Serial settings: Is port connected?" but when I'm trying to use it LabView says:
I'll be grateful for help.
BR,
Artur
There may be an easier/cleaner way, but you could attempt to open the port; if it fails, it's in use. Make sure you close it again, though.
Thank You for reply.
So...open port and check error string and if error string = null then port status is "opened"?
Just wire the error output into a case structure. In the "Error" case, put a "Clear Error" and pass False to your "In Use?" output. In the "No Error" case, close the port and pass out True.
Thank You for the suggestion.
