Project Build Spec Regisitry programmatic editing
Ryan Podsim
I'm wanting to create a VI that will add a predefined set of Registry entries to the Installer build spec for a project. Previously we have entered these items by hand through the build spec properties, but would like to speed up the process and reduce errors. I have found the Set Tag and Set XML Tag methods for a build spec, but that doesn't seem to work right. I can create the tags for the RegDest.dirName and RegDest.parentTag, but can't figure out how to get a new RegDest.dirTag; as it seems to be some special code. Without that code, I seem to be unable create the entries correctly.
Does anyone know of some hidden built-in VIs that can create the registry entries for Install specs? or how I can generate the special Code for RegDest.dirTag?
Here is a sample from the lvproj file of a valid spec (i.e. created by hand)
<Property Name="RegDest[0].dirName" Type="Str">Software</Property>                                  	<---- part of default Spec
<Property Name="RegDest[0].dirTag" Type="Str">{DDFAFC8B-E728-4AC8-96DE-B920EBB97A86}</Property> 	<---- part of default Spec
<Property Name="RegDest[0].parentTag" Type="Str">2</Property> 					   	<---- part of default Spec
<Property Name="RegDest[1].dirName" Type="Str">BEI</Property>
<Property Name="RegDest[1].dirTag" Type="Str">{D462230D-D253-433D-9A2C-E694E552E45B}</Property>   	<---- special code!!!!
<Property Name="RegDest[1].parentTag" Type="Str">{DDFAFC8B-E728-4AC8-96DE-B920EBB97A86}</Property>
<Property Name="RegDestCount" Type="Int">5</Property>
[/CODE]
Edited by Ryan Podsim
