help me to build a tcp connection, i'm beginner
Hi everybody, i'm beginner with labview and i want to build a tcp connection for my final year project, i have tried to follow the examples that come with package of this software but with no results. so plz if someone can show me in details how to use the different elements; tcp listen,read,write etc
The TCP examples are good starting points, so you should probably explain what you're tried so far and what you're actually trying to do - "build a tcp connection project" is uselessly vague.
  • Like 2
Thanks for your answer, Actually i need to build an application that transfers data from one device(PC) to another via ethernet. the used protocol is TCPIP, i managed to build such a connection but the problem is that whenever i stop the application an error message shows up. also i need to add an indicator that indicates the rate of data transfer, how can i do it?
