Wouter Posted January 4, 2012 Report Share Posted January 4, 2012 (edited) VI Name: IP Validation Total VIs: strpos.vi, strrpos.vi, substr_count.vi, valid_ipv6.vi, test,vi, unittest.vi, ip2long.vi, long2ip.vi, valid_ipv4.vi Description: I saw in the svn of OpenG that there was a candidate for IP validation. But however I think I have a better one. One for IPv4 and one for IPv6, credits for the IPv6 algo goes to http://crisp.tweakbl...d-caveats).html Note: - Blockdiagram: - What are you thoughts on this VI? Would you like to see such a function in OpenG? Can you optimize the code? In which package should it be included? Should it be rejected? -edit- ups I forgot to set the unittests data I inputed in the control as default value... well you can now enter them by hand. $unitTests = array( '2001:0db8:0000:0000:0000:0000:1428:57ab' => true, '2001:0DB8:0000:0000:0000:0000:1428:57AB' => true, '2001:00db8:0000:0000:0000:0000:1428:57ab' => false, '2001:0db8:xxxx:0000:0000:0000:1428:57ab' => false, '2001:db8::1428:57ab' => true, '2001:db8::1428::57ab' => false, '2001:dx0::1234' => false, '2001:db0::12345' => false, '' => false, ':' => false, '::' => true, ':::' => false, '::::' => false, '::1' => true, ':::1' => false, '::1.2.3.4' => true, '::256.0.0.1' => false, '::01.02.03.04' => false, 'a:b:c::1.2.3.4' => true, 'a:b:c:d::1.2.3.4' => true, 'a:b:c:d:e::1.2.3.4' => true, 'a:b:c:d:e:f:1.2.3.4' => true, 'a:b:c:d:e:f:1.256.3.4' => false, 'a:b:c:d:e:f::1.2.3.4' => false, 'a:b:c:d:e:f:0:1:2' => false, 'a:b:c:d:e:f:0:1' => true, 'a::b:c:d:e:f:0:1' => false, 'a::c:d:e:f:0:1' => true, 'a::e:f:0:1' => true, 'a::e:f:0:1' => true, 'a::f:0:1' => true, 'a::0:1' => true, 'a::1' => true, 'a::' => true, '::0:1:a:b:c:d:e:f' => false, '::0:a:b:c:d:e:f' => false, '::a:b:c:d:e:f' => true, '::b:c:d:e:f' => true, '::c:d:e:f' => true, '::e:f' => true, '::e:f' => true, '::f' => true, '0:1:a:b:c:d:e:f::' => false, '0:a:b:c:d:e:f::' => false, 'a:b:c:d:e:f::' => true, 'b:c:d:e:f::' => true, 'c:d:e:f::' => true, 'd:e:f::' => true, 'e:f::' => true, 'f::' => true, 'a:b:::e:f' => false, '::a:' => false, '::a::' => false, ':a::b' => false, 'a::b:' => false, '::a:b::c' => false, 'abcde::f' => false, '10.0.0.1' => false, ':10.0.0.1' => false, '0:0:0:255.255.255.255' => false, '1fff::a88:85a3::172.31.128.1' => false, 'a:b:c:d:e:f:0::1' => false, 'a:b:c:d:e:f:0::' => false, 'a:b:c:d:e:f::0' => true, 'a:b:c:d:e:f::' => true, 'total gibberish' => false); ValidateIP.zip Edited January 4, 2012 by Wouter Quote Link to comment
asbo Posted January 4, 2012 Report Share Posted January 4, 2012 Having only gleaned a little from the VIs names, I presume it uses string/token-based analysis to validate the strings as an IP address. There exists the the "String to IP" and "IP to String" LabVIEW nodes, I wonder if these would be faster to use for IPv4 addresses? There may be OS-specific calls which are faster, In general, though, I think that these would be helpful only in data validation scenarios, rather than actual networking scenarios - if you plug in an ill-formed address, the networking node will return the correct error and you should handle it downstream. Also, your IPv6 reference link got mangled. Quote Link to comment
