Error in Vision Assistant
OK you imaging gurus out there. I need some basics help.
I'm running NI Vision Builder AI and everything looks ok. I've been able to do measurements and pass-fail on the image.
The problem I'm having is when I try to do image processing in Vision Assistant. Whenever I try to do color processing on the image I get the error:
"The type of image acquired is not supported by this step."
This makes no sense since the acquired image coming right from the camera is 8bits.
2363[/snapback]
What process are you tring to do?
Only the color processes can be done on a color image which contain three planes(RGB or HSL or HSI). if you want to use the non color processes you have to extract a plane. Most of the time the lumen plane is the one to use.
2364[/snapback]
I see, so I cannot perform any functions that are on the "Color Processing Functions" Tab correct?
  • 4 weeks later...
Mike,
I came across a solution for this in the NI knowledgebase - Using the Vision Builder first perform a color extraction of the RED pane of the image - then all other functions will work.
Jack
  • 2 years later...
