bundle by name selection bug
In a relatively complex bundle by name with long names and hide full names activated we stumbled over the following bug.
This one is reported to NI but not yet solved.
Take a cluster with inside two or more clusters with the same name item.
e.g. main cluster not named
sub cluster a with element d
sub cluster b with element d
sub cluster c with element d
build a vi with a while loop and a case structure inside
use an unitialized shiftreg and in the false case feed the rightside shiftreg with a constant cluster.
in the true case unbundle the shiftreg say element a
bundle the output of this unbundle with the original shiftreg wire and select cluster b
to be updated by a
use the output of this bundle to bundle again but now select c.d to be updated with a constant.
If you succeed in selecting c.d (and the editor does not change it back to a.c) you don't have a bug but I do.
a simple workaround is no to select the element directly but to use an extra unbundle.
our problem was not seeing what happened because of the hide full names selection !
NI has confirmed this a bug and will find a fix.
Albert
Download File:post-175-1098973277.vi
