Daklu Posted June 19, 2012 Report Posted June 19, 2012 I can find it in vi.lib, but it's gone from the palettes in 2011, as is the Application Directory constant. Has the functionality been replaced by something else? [Edit] Well, kick me in the teeth and call me Charlie. It was an ID: 10t error. LV thought the vi was on the RT target and Get System Directory isn't supported on RT, so it wasn't showing up in the palette. A quick LV restart and all is good. (I hope some day I'll wrap my head around all the twists and turns that make up RT programming with LV.) Quote
Popular Post asbo Posted June 19, 2012 Popular Post Report Posted June 19, 2012 Rather than restarting LV, in multi-target projects you can right-click the project/target label in the bottom left of the VI and change which target the VI is configured for: 4 Quote
Daklu Posted June 19, 2012 Author Report Posted June 19, 2012 I knew you could do that to change projects, but I didn't know that also applied to different targets in the same project. Quote
todd Posted June 19, 2012 Report Posted June 19, 2012 Arg - I knew that applied to targets, but I didn't know it worked with projects. Quote
Daklu Posted June 19, 2012 Author Report Posted June 19, 2012 I guess the two of us together almost makes one knowledable developer... Quote
todd Posted June 19, 2012 Report Posted June 19, 2012 Ha! I'm not sure if my contribution is just imaginary, or full-on negative. Quote
