[CR] Multiple File Path Control
index.php?app=downloads&module=display&section=screenshot&id=205
Name: Multiple File Path Control
Submitter: David_L
Submitted: 17 Feb 2012
Category: *Uncertified*
LabVIEW Version: 2011
License Type: BSD (Most common)
This Multiple File Path Control is similar to the default File Path Control in LabVIEW 2011, however you can select more than one file at a time. The data type on the block diagram is an array of File Path Control.
Right click on the MFPC to have it display the full paths or just the file names.
I'll try to post this in pre-2011 but because it uses silver controls, I'll have to make some significant changes.
