dynamically change a cluster elements name
Is there any way to change a Cluster Elements name/description with values from an *.ini File?
I want to create the file robust against changing of INI-File indexing.
I get my Data Values from an Array with is feeded with *.ini Variable Values.
My Variable Names are located in an String array - I now want to create a Cluster that has the Variables in it which are Named by the String array.
  • 4 months later...
2551[/snapback]
I have controlled the names of booleans in clusters by creating a property node for the cluster and using the "Controls[]" property. This will create an array of "refnums". Then place an "generic" property node in a 4-loop and let the loop self index the refnums. Once you connect the "refnums" wire to the "generic" property node you will have access to the "Strings[] of the individulal cluster elements.
I hope this helps!
