Sparkette Posted July 3, 2012 Report Posted July 3, 2012 I saw this at the Maryland Science Center in Baltimore and I just had to take a picture of it. I only thought to post it just now. 1 Quote
viSci Posted July 3, 2012 Report Posted July 3, 2012 That's interesting! I designed that exhibit about 6 years ago along with a LabVIEW controlled Laser Harp which used to also be at that museum. Quote
Slacter Posted July 3, 2012 Report Posted July 3, 2012 Could be there for a while. I remember revisiting the Museum of Science and Industry back in the early '80s, and then again recently in the early 2000's. The same TI-99's I saw in the '80s were still in use on a couple displays. Quote
Sparkette Posted July 3, 2012 Author Report Posted July 3, 2012 On 7/3/2012 at 12:47 PM, sachsm said: That's interesting! I designed that exhibit about 6 years ago along with a LabVIEW controlled Laser Harp which used to also be at that museum. Wow, really? Care to post the VI's? It's a museum after all; I doubt you'd be under an NDA. And I thought that laser harp was still there; at least it was in 2009. Quote
viSci Posted July 3, 2012 Report Posted July 3, 2012 Here is a jing clip of the Heartbeat Exhibit. http://screencast.com/t/owijhiujxEi Quote
Sparkette Posted July 3, 2012 Author Report Posted July 3, 2012 On 7/3/2012 at 8:37 PM, sachsm said: Here is a jing clip of the Heartbeat Exhibit. http://screencast.com/t/owijhiujxEi Oh, so are you not allowed to post the VI? Quote
viSci Posted July 4, 2012 Report Posted July 4, 2012 Well basically I still sell those exhibits now and then to other museums. If you are interested in Biological signal analysis you should check out NI's free Biomedical Startup kit... Quote
