Sparkette Posted July 6, 2012 Report Posted July 6, 2012 (edited) I made another XNode that should greatly help with selecting coordinates. Place the XNode, which is resizable, and you can click anywhere to select a point. It will then output that point's coordinates as a cluster of two I32 values. If you right-click on it, you will get a menu where you can see the selected coordinates, or replace it with a standard cluster for if you want to distribute your VI without the XNode. Point Selector Constant.zip Edited July 6, 2012 by flarn2006 Quote
