rogerwang Posted November 12, 2004 Report Posted November 12, 2004 I have 2 signals respectively am red with the white, I install the red signal on the counter also am with the counter come when triggers, when number to 33 can start the formula number to 34 when finishes, the archive should be a white cycle value, but actually has 7 white cycles the value I only to want the part which section of yellow encircles, how should do. Quote
JackHamilton Posted November 16, 2004 Report Posted November 16, 2004 The waveform returned from the AI VI is a 2D array - use the "Index Array" function to strip off just the '0' element and save that to disc. See Example code: Quote
