Why is my VI still running after my teststand sequence has completed?
nitulandia
Hello all,
Disclosure: I have not played with TestStand in a long while...
This is what I've done so far:
1. Successfully have put together a simple test sequence comprised of 5 steps
- Initialize Power Supply.vi
- Initialize Instrument B.vi
- Display Hello World.vi
- Close Power Supply.vi
- Close Instrument B.vi
2. I'm able to successfully run this test sequence (BTW, I'm actually talking to real instruments)
The issue I'm having is that once my test sequence has completed its execution, if I try to open either of the VIs from above it shows that "The SubVI is wating to Run"
May I ask, why that is?
In advance, thank you for the feedback.
Cheers,
edp
post-14457-0-70535700-1345562640_thumb.p
By default, the LabVIEW adapter is configured to reserve loaded VIs for execution. This setting can be changed in the adapter configuration (Configure>>Adapters) for LabVIEW. To unreserve all reserved VIs, select File>>Unload All Modules. Also, if you select a step that calls a code module, then select Edit VI, the VI will open in an unreserved state.
