Transitional Colours in Squre LED Control
hfettig
In Labview 7.1, if you use a square LED as a control and set the mechanical action to 'switch when released' or 'latch when released', the 'True to False' and 'False to True' colours seem to get ignored.
I only want the colour to change once the mouse is released, but I could not find a combination of the four colour entries that made that happen. It works fine for the boolean strings that are displayed.
This is the first time I have tried this, so I do not know if it used to work in previous versions.
You may be able to get the results you want by using the control editor.
I noticed that when I made the colors lighter that labview automatically darkened its counter part.
post-584-1100727259.jpg?width=400
