hfettig Posted November 17, 2004 Report Posted November 17, 2004 In Labview 7.1, if you use a square LED as a control and set the mechanical action to 'switch when released' or 'latch when released', the 'True to False' and 'False to True' colours seem to get ignored. I only want the colour to change once the mouse is released, but I could not find a combination of the four colour entries that made that happen. It works fine for the boolean strings that are displayed. This is the first time I have tried this, so I do not know if it used to work in previous versions. Quote
Mark Balla Posted November 17, 2004 Report Posted November 17, 2004 You may be able to get the results you want by using the control editor. I noticed that when I made the colors lighter that labview automatically darkened its counter part. Quote
