boyracer38 Posted November 28, 2004 Report Posted November 28, 2004 Hi, as title.... how do i make an LED blink on and off?? Thanks Quote
aledain Posted November 29, 2004 Report Posted November 29, 2004 Hi, as title.... how do i make an LED blink on and off??Thanks 2781[/snapback] For most (every?) control there is a property node that you can set (Blinking = True). RMB on the control (CreatePropertyNode) and select the "Blinking" attribute. OR, if you're asking how to make a boolean toggle its state, create a local variable set the "NOT" at some time interval. Quote
