LV7.1.1 with Teststand 3.1: Bug in Error-Parameter
Pater
Here is the solution posted by "JoseHdz" in the NI-Forum.
There is a work around for this problem. All you have to do is create a new registry key.
This is what you need to do:
1. Export the registry key HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW Run-Time\7.1 to a file (called it something like LabVIEWRT71.reg)
2. Rename the registry key above to HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW Run-Time\7.1.1.
3. Import the registry file you create in step 1 (Import LabVIEWRT71.reg).
This work around should fix the problem.
The problem only appears when the LabVIEW adapter is configured to use the LabVIEW Development System and the VI returns an error in its error out cluster. If the LabVIEW 7.1 Run-Time Engine is used, the problem will not appear.
The problem will be fixed in a future version of TestStand. It is unfortunate that a work around is needed.
