OpenCL for Labview
Howdy folks,
Just wanted to announce that OpenCLV (OpenCL for LabVIEW) is available on NI's website.  The toolkit installs through the VI Package Manager and adds a suite of OpenCL VIs to LabVIEW.  There is a lot of documentation and example code to help get new projects started, even if you are an OpenCL rookie!
  • Easily configure multiple OpenCL devices to run in parallel
  • Work with 1D, 2D, and 3D memory and images with OpenCL kernels
  • Use Global, Local, and Private memory for a fully optimized OpenCL experience
  • Packages AMD's OpenCL fast Fourier transform algorithm into easy-to-use VIs
  • Easily work with Intel, AMD, and NVIDIA - both CPU and GPU devices
  • Take advantage of a comprehensive manual and examples
This add-on only runs on Labview 2012 x64 and the end user needs to install device appropriate OpenCL SDKs.  If you have any feedback or questions, don't hesitate to contact the RaptorView team at support@raptorview.net.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/211893
