zeus224 Posted December 21, 2004 Report Posted December 21, 2004 hi alll i need some help i have a project than need 4 graphs and when i stop and start again my graphs dont clear....somebody can help me... Download File:post-1266-1103635029.vi Quote
Louis Manfredi Posted December 21, 2004 Report Posted December 21, 2004 hi alll i need some help i have a project than need 4 graphs and when i stop and start again my graphs dont clear....somebody can help me... 3117[/snapback] Hi Zeus: One Way: Create a property node for each graph (Right click on connector>create>property node.) Right click>Change the property node to write. Right click>Select property> Select the "History" property. Wire a empty array constant to this property node (Right-click on it>create constant.) Do this for every graph, and put all these in a sequence structure so that they are executed when you first run your program. Best Luck, Louis Quote
zeus224 Posted December 21, 2004 Author Report Posted December 21, 2004 thz louis ill try this.... Quote
