Bytelabs Posted August 29, 2013 Report Posted August 29, 2013 Hi all, I create a vi that inserts in a word template table values . This work's fine but the table have 4 columns and if i update less than 4 column (example 3) the other is filled with the last column inserted (the last column is replied in the remains column). I attach the code created. Another question is why, also if i add an 2d array in the table, if i don't repeat the insertion for each column (for loop) the only column recorded is the first? Thanks you for the feedback. Quote
