reteP Posted November 18, 2013 Report Posted November 18, 2013 Hi lab funs, i am beginner with Actor framework (AF). Could you help me understand how to work with AF? My app has 5 cylinders ( Gate, Lift, Shift, Grab, Clamp ), 3 Lamps ( Pass, Error, Servis), 2 Locks, Air distributed ( Vent, Sensor ) and HW Start button. I made class of cylinder with methods ( Init, Move, Check Position ) and i made driver used QMH for this class. Q1: if i want control 5 cylinders, i must make actor for each cylinder or only one ? Q2: How i make comunication between actors cylinder and air distributed ( is free-running, every 1s check pressure then go to turn ON or turn OFF and send message to control actor if pressure = false ) THX QSM-Projekt_Lab2010ver1-01.zip Quote
K-node Posted November 18, 2013 Report Posted November 18, 2013 reteP, Watch your post at https://decibel.ni.com/content/message/62163#62163, I will be responding there with more information tonight. -Kurt 1 Quote
reteP Posted January 8, 2014 Author Report Posted January 8, 2014 Hello everybody, What do you think about this construction: i have manipulator composite of 4 pneumatic cylinders. I create objects cylinder and manipulator each object has sequence. Cylinder has sequence: check position->desired position->stop & manipul has release->grip->upward->move->level->clamp. Manipul has also 4 parametre for sequnce ( Zon, Lev, Job, Clamp ). Check my program. Is it possible this program change to AF ?? Could you tell me how please ?? THX img-Z13121327.pdf -----RSV_EM-2001_ver-1-01-----.zip Quote
