grmc Posted January 25, 2005 Report Posted January 25, 2005 Hi all, Just wondering if anyone can help out with ActiveX Event Handling. I can manage to open the ActiveX object, and have successfully registered for the event, and created a callback vi. The problem I am facing is that I cannot see any event data when the event actually occurs. I know this isn't worded very well, but I was wondering if anyone has a sample ActiveX vi that accepts data passed to it from a windows application, and then displays the data that was sent within the vi. It doesn't matter how simple the vi is, I just need to get an idea of the workings of ActiveX within LV. Thanks in advance, grmc Quote
kfriday Posted January 25, 2005 Report Posted January 25, 2005 Hi grmc Have a look at the attached code, its a simple example of implementing a callback that uses event data. The example uses the ActiveX UpDown control and fires a callback on the mouse down event. The callback just displays a popup dialog which shows the mouse position which is retrieved from the mouse down event data. Download File:post-997-1106618374.zip Regards Kurt Quote
grmc Posted January 25, 2005 Author Report Posted January 25, 2005 kfriday said: Hi grmcHave a look at the attached code, its a simple example of implementing a callback that uses event data. The example uses the ActiveX UpDown control and fires a callback on the mouse down event. The callback just displays a popup dialog which shows the mouse position which is retrieved from the mouse down event data. Download File:post-997-1106618374.zip Regards Kurt 3660[/snapback] Excellent I found some code in the examples directory in LV which gave me some more ideas, I've accomplished what I set out to achieve now! Thanks for your time though :beer: grmc Quote
