FJ_Sanchez Posted February 14, 2014 Report Posted February 14, 2014 Hello, I'm trying to compile the code from this thread http://lavag.org/topic/9232-c-classes-from-lv/ and load it in LV. I can compile it without errors, but when I try to load the DLL in Lv using the Call Library Function Node, it throws an error: Error loading "mydll.dll" Invalid access to memory location. If I use the dll provided in the zip it works great, so I think that I should change something in Dev-C++ to make it compatible with LV Call Library Funcion Node. Any ideas? Quote
FJ_Sanchez Posted February 14, 2014 Author Report Posted February 14, 2014 Forget about this... now it's working, it was something related to the #defines that it generates by default. Anyway, I really recommend the mentioned post to anyone with problems with C++ dll and LabVIEW. Quote
