Cannot load DLL compiled with Dev-C++
Hello,
I'm trying to compile the code from this thread http://lavag.org/topic/9232-c-classes-from-lv/ and load it in LV. I can compile it without errors, but when I try to load the DLL in Lv using the Call Library Function Node, it throws an error: Error loading "mydll.dll" Invalid access to memory location.
If I use the dll provided in the zip it works great, so I think that I should change something in Dev-C++ to make it compatible with LV Call Library Funcion Node.
Any ideas?
