Edit text file and save it as a new text file using LV
Hello Everyone,
Could some one help me please. My problem is, firstly I need to read a text file(.csv file) and i must be able to add few data to the existing text file and should save the data again as a new .csv file. The text file contains pin numbers and I need to add the pin definition manually and should save it. Thank you in advance
Regards
Bhargava
Unknown device.viFetching info...
Edited by bhargava126
You will need to provide a more detailed explanation of your problem in order for anyone to help you. It would also be good if you provide a sample text file that you are trying to read, and an example of the changes you want to make. Probably you will want to start with the Read from Spreadsheet File function, then modify the string array as desired, and finally write it back out (overwriting the old file) using Write to Spreadsheet File.
