Mache Posted February 2, 2005 Report Posted February 2, 2005 Here is an example of a Time Stamped Chart in an Application which is put on intranet/internet using the Web Publish tool from the menu. Download File:post-1417-1107377568.vi To see the bug do the following. 1. Make sure Web server is active on known open port. 2. Ensure that you have saved the Htm file for the vi. 3. Run the Vi and let it run for 10 minutes or so. 4. Connect from another computer or even the same computer using remote panel URL in the browser You will see that the time stamps on the chart on server does not match the Browser time Stamps. Reported this to NI with acknowledgement of the Bug and that it has been referred to R&D If any one has a Work around, It is greatly appeciated. Mache Quote
