AndrewRae Posted April 25, 2014 Report Posted April 25, 2014 (edited) Hello I’m new to LabVIEW and was hoping someone could help. I am sorry in advance if I ask basic questions but please keep in mind I am new however am willing to learn. I am trying to send data from serial port and trying to plot the data, however the data comes as an array of three values at a time. I want to learn how to split the array of three to each individual values. The reason being, I would like to plot each value on a graph that plots the incoming values against time. The data would be fed continuously with different values each second. Hope it made sense Edited April 25, 2014 by AndrewRae Quote
AndrewRae Posted April 25, 2014 Author Report Posted April 25, 2014 (edited) Or is there a way to assign the variable from the serial to the graph for example if the data is:A=23B=24C=25Is there a way to plot a graph that will only plot the data that comes with the name A against time and as every second new data is received A will be automatically plotted within a graph with only A data. I would like to have three graphs A, B and C. Hope that made sense Edited April 25, 2014 by AndrewRae Quote
GregPayne Posted April 25, 2014 Report Posted April 25, 2014 (edited) Hi Andrew, With reference to your first post, you can use the index array function to get the individual elements out of the array. Are you able to control the format of the data from the serial port? Could you provide the a sample of the exact data the is read from the serial port? That would help in working out how to split it into the three graphs. Greg Edited April 25, 2014 by GregPayne Quote
Mellroth Posted April 25, 2014 Report Posted April 25, 2014 Hello I’m new to LabVIEW and was hoping someone could help. I am sorry in advance if I ask basic questions but please keep in mind I am new however am willing to learn. I am trying to send data from serial port and trying to plot the data, however the data comes as an array of three values at a time. I want to learn how to split the array of three to each individual values. The reason being, I would like to plot each value on a graph that plots the incoming values against time. The data would be fed continuously with different values each second. Hope it made sense I guess you are using a WfmChart and try to plot the array values in the chart as they arrive? A 1D-array fed into a WfmChart will update one plot with three new values. But, if you just add a build array on the 1D array, data will be plotted in three individual traces. /J Quote
AndrewRae Posted April 25, 2014 Author Report Posted April 25, 2014 Hi Greg Thank you for your help. The data will be recieved at random times and any order. There is a format to each data. Mellroth, I was planning on using theWfmchart and thank you. Quote
