ccarner Posted July 30, 2014 Report Posted July 30, 2014 Searched Google and these forums, but couldn't find an answer. Any help is appreciated. Quote
QueueYueue Posted July 30, 2014 Report Posted July 30, 2014 Create a property node for the tree and set the following properties (in this order) Active Cell.Active Column Number = -2 (this selects all columns) Active Item.Row Number = -2 (this selects all rows, including the column headers) Active Cell.Background Color = Desired color You may have to play with it a bit to get everything exactly right, but this should get you started. Set Active Item.Row Number = -1 to color just the column headers. Also remember property nodes are executed top down, this is why order matters Quote
Jimmy Chretien Posted July 30, 2014 Report Posted July 30, 2014 (edited) Basically you need 2 more Property nodes if you want to keep your headers color. you must do what QueueYueue said first. Then : Active Cell.Active Column Number = -2 (this selects all columns) Active Item.Row Number = -1 (this selects the column headers) Active Cell.Background Color = Desired color Then : Active Cell.Active Column Number = -1 (this selects row header) Active Item.Row Number = -2 (this selects all rows) Active Cell.Background Color = Desired color Edited July 30, 2014 by Jimmy Chretien 1 Quote
