alignment text on cursor label
Hi all
I would like to insert labels on graph, to such propose I use cursor label.
my question: is there any way to set text justify (alignment left or right) on graph cursor ? In my experience (LV 7.0) seems possible only centred alignment :-(
thanks
I've seen that too. :headbang:
My working around is add spaces AFTER the desired text and be SURE to put a period ( . ) at the end - the cursor ignores trailing spaces.
Most people don't even notice the period floating off the to far right.
Also, by default the first letter of the cursor test is slighty cut-off - :blink: I put a space before the text to fix that (you don't need a leading period)
Regards
Jack Hamilton
