tonitp Posted February 17, 2005 Report Posted February 17, 2005 Hello, How can I hide (make not visible) a specifici column of a multicolumn listbox in LabVIEW? Thanks, ToNi. Quote
JackHamilton Posted February 25, 2005 Report Posted February 25, 2005 You're thinking a la Excel? Well there is not a property node control for the MCLB to do this. You can acheive this 'effect' by simply taking the data table and removing the desired column of data and re-populate the MCLB. You only need to remove the selected column array when routing it to the listbox - you can keep the 'full' table in memory in your code. Jack Hamilton Quote
