XML via API
I am creating an XML output and using API. I have succes with adding attributes to the 'testsuite' tag, but I cannot find the right construction to add attributes to the child - e.g. the child 'testcase' tag. Anyone have success with this?
post-52955-0-29414000-1415693116_thumb.p
XML can be tricky because it's refnum-based. Use error wires to force the execution order of the invoke nodes.
The following snippet adds an attribute "attr"="1" to the <properties/> element.
post-15449-0-64305300-1415702999_thumb.p
  • Like 2
Thanx. In the meantime I figured it out the same way as you - but thanks anyway. In fact I was a little surprised, that the amount of topics was so limited to this very common use file I/O.
