Labview Webservice
Hi.
I am following a tutorial about webservices.
I have a database and some scripts written in PHP.
These php pages returns data of the database in JSON format.
In the tutorial, the autor go to "Build Spectifications"->"New"->"Web Service(RESTful)",
but when I try to do it, this option doesn't appear.
I can see "Packed library", "Installer", "Zip file" among others, but I can't pick "Web service", why?
I need to install some plugin for labview?
Thanks in advance, and sorry for my really bad english  :oops:
  • 4 weeks later...
Two things:
1. Webservices changed a lot in between LV2012 and LV2013. I think you're looking at a tutorial for LV2012, but you're working in LV2013. That's why you're not seeing the webservice option in the build specs.
2. It sounds like you'd like to consume a webservice from labview. The tutorial you're looking is for hosting web services in labview. To consume restuful webservices in labview you should be using the HTTP Client
