JCarlos17 Posted December 14, 2014 Report Share Posted December 14, 2014 Hi. I am following a tutorial about webservices. I have a database and some scripts written in PHP. These php pages returns data of the database in JSON format. In the tutorial, the autor go to "Build Spectifications"->"New"->"Web Service(RESTful)", but when I try to do it, this option doesn't appear. I can see "Packed library", "Installer", "Zip file" among others, but I can't pick "Web service", why? I need to install some plugin for labview? Thanks in advance, and sorry for my really bad english Quote Link to comment
QueueYueue Posted January 5, 2015 Report Share Posted January 5, 2015 Two things: 1. Webservices changed a lot in between LV2012 and LV2013. I think you're looking at a tutorial for LV2012, but you're working in LV2013. That's why you're not seeing the webservice option in the build specs. 2. It sounds like you'd like to consume a webservice from labview. The tutorial you're looking is for hosting web services in labview. To consume restuful webservices in labview you should be using the HTTP Client Quote Link to comment
