_Y_ Posted January 27, 2015 Report Posted January 27, 2015 Hi, I develop a new TestStand solution with use of IMAQ/Vision. The structure is conventional: UI is written in LabVIEW as well as particular tests. In some cases images and test-specific controls/indicators must be shown to user(s). This works well with conventional "Show front panel when called" set to test VI-s. However, such FP pop-up solution is not the best. Is it possible to insert test VI-s in SubPanel of UI? If so, I shall appreciate any hint how VI reference is obtained and sent from TestStand sequence to UI. Thank you Quote
