RT loop rating with FPGA card
PitchNancy
Hello,
With my pxi FPGA and RT 8186 controller I obtain only 20 kHZ of loop rate. I use IRQ method and acquire 8 analog input. I make for the moment no processing on FPGA and RT.
Can you say me if you have similar results or better ?
Hello,
4057[/snapback]
After doing some test I have a beginning of explication. I have used the real time system manager to evaluate the CPU usage. I have acquired 8 analog Input with FPGA and transmitted them to RT by the IRQ method. I did the test for cluster, array, and 8 single channel transmission.
After 20000 Hz the RT CPU usage was superior than 100 %, and bug. I attach my VI and my results.
Download File:post-1636-1109952736.zip
Download File:post-1636-1109952738.pdf
