Testing C# dll in LabVIEW
I have C# code that initializes force feedback joystick and plays force effect file; vibrates the joystick. I converted console application into a dll file. I want to test this dll file in LabVIEW to check that my dll file works.
People told me that I need to use property, constructor, and invoke nodes, so I went to connectivity - .net - used property, constructor, and invoke nodes.
With the constructor node I browsed for my dll and it shows my class Form1. I don't know what to do from here. I have attached dll file and what I did so far with the LavVIEW.
C# force feedback dll.zip
post-53324-0-88588500-1426746271_thumb.j
You implied that your C# assembly contain a Form - so presumably you want to show this form from within LabVIEW. Once you have instantiated your form with a Constructor node you need to show the form with the Show() method via an Invoke node.
