ViServer/Client question
I have vi's (LabView 7.1) running on a PC(Win2k-SP4) controlling a rack of power supplies though a PCI-MXI-2/VXI interface. I would like to pass the current set values for those power supplies from a vi (LabView 7.1) running on another PC (Linux-2.6.8 Kernel).
I have tried the example vi's provided, Server-VIServer example.vi and Cient-VIServer Example.vi without success.
The sequence I tried went as follows...
on the Windows PC-
open Server vi
input the server's ip address
input the client's ip address
input the full path to a test vi (just adds two numbers)
run the server vi (runs with no errors)
on the Linux PC-
open the client vi
run the client vi
The output I get in the messages box is
Listing exported Server example VIs on "<ip address>"
and the vi stops. The server:station box remains empty
Should I see the server and test.vi listed?
And the big question is - How do I pass the test.vi a couple numbers to add and get the result on the Linux PC?
Thanks in advance for any help available
Mark
  • 3 weeks later...
Walter,
I'm scratching cobwebs here, but I ran into a similar problem with LabVIEW and VB via TCP/IP - it turned out the 'lingo' is flipped between LabVIEW and the 'rest' of the world.
Meaning try running the 'server' software on the LabVIEW side and the 'SERVER" software on the Linux side or vice versa. Yes, I know odd, but it discovered the problem when I have both my LabVIEW Client and server testing running with the VB app - and the reply from VB popped up in the 'wrong' window'!
Regards
Jack Hamilton
