Calorified Posted September 28, 2015 Report Posted September 28, 2015 (edited) Hello there, I tried to implement the discrete time Kalman filter in a closed loop estimator scenario based on the "CDEx LQG with Linear Simulation" example located in `C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\Control and Simulation\Control Design\State-Space Synthesis` that ships with LabVIEW. Only difference is my application is a 4 x 4 state matrix. The thing is the kalman filter output, \( y(t)(k|k) \) and output estimate, \( \hat{y}(k|k)\) do not get updated. My vi.png is here: I know it says somewhere on the help pages that the KF vi needs a second-order process components. But does this mean the vi would not work with higher order systems? Would appreciate your input. Edited September 28, 2015 by Calorified Quote
Calorified Posted September 29, 2015 Author Report Posted September 29, 2015 Turns out my intuition was right. The discrete KF vi will not accommodate higher-order stochastic state space systems. I confirmed this through the LaVIEW PSC engineers yesterday. If anyone is thinking of a big state space structure as I was, the easy way out might be to build your own KF application. Quote
