Ctrl key sticks?
Hello All:
Sometimes when I'm working in LabView, it starts acting as if the Ctrl key on my keyboard is stuck.
Sounds an awful lot like a hardware problem, doesn't it :question:
But it only seems to happen with LabView. :nono:
Sometimes clicking the ctrl key a lot makes the problem go away, sometimes I have to exit LabView to get rid of it.
Anyone else see anything Like this?
Best Regards, Louis
I had a similar problem back when I was working with LabVIEW 5.0. I believe the problem went away when upgrading to LabVIEW 5.1? (it was a long time ago, so hard to remember accurate details)
Thanks to a corporate email server upgrade, I no longer have the email I exchanged with NI back then.
John
Hello All:
Best Regards, Louis
4270[/snapback]
Hi John:
Thanks for the info--
I'm running 7.1.1 now, but come to think of it, seems like this has been going on for a long time... perhaps off & on since I switched From Macs :wub: to Windows :ninja:
Perhaps I should check with NI support.
Anyone else having the problem currently :question:
Thanks, Lou
Hi John:
Thanks, Lou
4273[/snapback]
Nope, no problem here. never seen this. Do you have sticky keys enabled in windows? This is in the disability aids section.
4351[/snapback]
Hi Michael:
Good suggestion about sticky keys, but not the problem in this case. I'll keep you posted if I figure it out.
Best Regards, Louis
