PitchNancy Posted March 30, 2005 Report Posted March 30, 2005 Hi, I use FPGA's counter input for PWM demodulation. My base PWM frequency is 1kHz. I use the tick count VI for the pulse width and period measurement. Tick count clock is 40 MHz, and 16 bit r Quote
elyness Posted April 22, 2005 Report Posted April 22, 2005 What do you mean by "artefacts"? Could it be that your counter is overflowing? At 1kHz, a 40MHz counter reaches 40,000 if it starts at zero, approaching the 65,535 limit. Quote
PitchNancy Posted April 28, 2005 Author Report Posted April 28, 2005 elyness said: What do you mean by "artefacts"? Could it be that your counter is overflowing? At 1kHz, a 40MHz counter reaches 40,000 if it starts at zero, approaching the 65,535 limit. 4609[/snapback] Thanks, I did not think of this problem !!! After correction I do not have any more insane peaks. But now my problem is the limitation of the band-width by using IRQ. I don't understand why it's impossible to use DMA transfer. Quote
