Hai Pham Posted December 8, 2016 Report Posted December 8, 2016 Could you help me check the below code to me , this code have just been worked for 2D file (X ,Y axis) , but I want to change it can be worked for 3D file . This file have already been read the text file and move the motor follow that position . I have already checked this file with 2D file , It is also working but when i add more than 1 axis and use the 3d text file data . It can't be work. Can you explain to me for that ? Thank you in advance 3D Spiral.txt Two-Axis Smart Contouring.vi Quote
Hai Pham Posted December 8, 2016 Author Report Posted December 8, 2016 The above file belong to this file Contouring.llb Quote
