Open G Dictionary Not Working When It Is Placed Inside a Packed Library
Recently I used Open G Dictionary to build a test parameter look-up table in my LabView project.  The vi that runs the dictionary was tested and worked as expected.  However, after I package this vi into a packed library and call it from a different project externally (input and output are hook up exactly the same way as I tested it directly without packaging), the dictionary stopped working.  The error message returned error code 1 which seem originated from 'Create Semaphore.vi'.  The LavView version I have is 2015 64-bit.  Does anybody has similar issue, work-around, or suggestion?  Thanks.
Zhan
The attached zip file has two labview projects.  'MyPackedDictionary.lvproj' has the implementation of the vi which uses the open G dictionary and the packed library that includes it.  'Call_MyPackedDictionary.lvproj' has a test that calls the vi externally and shows the problem.
Dictionary.zip
