Custom Lung Simulator under LabVIEW control
PeterB
G'day fellow wire workers,
where I work, we own a few of these nifty Breathing Simulators: http://www.ingmarmed.com/asl5000.htm
In the process of customising their operation I will be integrating some external feedback modelling previously developed in a language called VisSim.
VisSim does have a rather archaic and clunky user interface, but at the time the lung models were written, LabVIEW really only had the GSim toolit to offer (GSim could do the job, but this kind of modelling was VisSim's forte and plus the person involved probably didn't look too hard into the GSim option at the time).
After much discussion, my proposal was to write a LabVIEW ActiveX server which could be called up from VisSim thus allowing easier upgrade paths for the lung models, while also retaining the existing look and feel of the VisSim GUIs.
This post is to share a learning experience with you in the world of ActiveX servers, just in case you ever have to take a similar journey and plus, I simply could not find any worked examples on any of my usual LabVIEW search sites (Searchview, ni.com etc). It's also possible that by reading the LabVIEW user manuals (which I surely did!), others may say "well that was obvious", but to me it wasn't - so here goes.
I assumed that the ActiveX server would allocate memory for its output parameters, however it is necessary to reserve space on the input side at the client level. It took me about 2 days to nut this one out. As reiterated recently on Info-LabVIEW, a Picture/LabVIEW diagram is worth 1000 words so I'll let you look at it and see if it's how you would have done it.
post-1272-1114754169.png?width=400
post-1272-1114756411.png?width=400
post-1272-1114756103.png?width=400
post-1272-1114756106.png?width=400
Maybe I could forego all the variant conversions, but at least I got rid of all the coercion dots. If anyone can show me where the manual mentions having to reserve memory please let me know (without referring to all the VB , .NET or Visual C examples, 'cause I'm a LV diehard!!)
One other thing I wanted to try was to see which method is faster for transferring data "Call2" or {setcontrolvalue,run,Getcontrolvalue}. I'll post back my results after testing the relative speeds.
Anyway, knowing that this now works for me in principle, it should hopefully be easy to call an ActiveX server I write in LV from VisSim.
regards
Peter Badcock
Validation Engineer
Certified LabVIEW Developer
Product Development
ResMed Ltd.
