michael.paier Posted April 29, 2005 Report Posted April 29, 2005 I have to build an dll in MS VisualStudio 6.0 and connect to LabView. How does this work? please help it is very important. Quote
m3nth Posted April 29, 2005 Report Posted April 29, 2005 michael.paier said: I have to build an dll in MS VisualStudio 6.0 and connect to LabView.How does this work? please help it is very important. 4711[/snapback] In your LabVIEW directory \ manuals, there is a file called lvexcode.pdf--Using External Code in LabVIEW. Give it a good read, try the examples, and then come back with specific questions if you have any. You can also navigate to the pdf through the LabVIEW bookshelf under the Help menu. Quote
