merlin Posted May 17, 2005 Report Posted May 17, 2005 Hi, as the title says, i am thinking of using an svg-file as a front-end-solution to labview. Svg ist scalable verctor grafix. It renders very fast and is easy to script. I need two things. Mainly i would need labview to integrate the svg-file as an activex-component. Adobe provides an activex-object, but it doesn't seem to work with labview. In the second stage i'd like to access the dom-objects inside the svg-document. Or at least i would like to start some function inside svg.. Has anyone any experience with this kind of connection between labview and svg? Thnx in advance. merlin PS: svg: http://www.w3.org/Graphics/SVG/ Quote
