The missing "Merge 3D Objects" node
You know the 3D Picture control? I was messing with it and I noticed there wasn't any way to merge objects together except by chaining "Add Object" subVI's, which can be annoying if you have a whole lot of objects. I was thinking it could be a good idea to have a growable node to do it, so I decided to make one.
Yes, a simple For loop (perhaps in a subVI) combined with a Build Array node would work just as well—and would really have simplified the code generation if I had thought to do it before—but I like making XNodes, and thought this would be a fun one. And yes, the usual disclaimer about XNodes applies—use it at your own risk; XNodes aren't supported by NI.
Merge 3D Objects.zip
  • Like 2
