labview array index
hello everyone, i need little bit help,
i am new in labview programming, so the problem is, i need index numbers of each elelment in a array. and also after getting indexes numbers (addressing) of each elelment then the program select those index in the array which has more continuous size as compare to others, for example,
Array 13 15 16 17 18 19 12 17 17 162 626 36 828 463 565 665 565 32 587 Index 5 6 7 8 9 12 13 14 **20 22 23 24 25 26 27 28 29 30 21**
so in this result the program get **20 22 23 24 25 26 27 28 29 30 21** this index result in another array. If you guyz have any question then please let me know. Thanks
