mange Posted May 24, 2005 Report Posted May 24, 2005 Hi I want to send a m-file with a function from Matlab to Labview. An exampel of the m-file is attaced below. The reson for the function in the m-file is that Im doing an exemenation report in electric enginering and have lot of m-files that alredy are built in matlab and they exists of functions. My question is what shuld i type in the matlabpromt to save the file in the right format so it can be read from Labview. Shuld it be 'mcc -x 'filename'? In Labview I have tryed to import the file whit help from 'Call Function Libary Node' but when i configur the nod only mexLibrary is avilebel in the dropdown for names to be selected as function names. And how shuld the input and outputparameters be set? When I have tryed this I got the folloving error message 'The dynamic link libary libmatlb.dll culd not be found in the specific path Her is the m-file function labview4(y) x=1; s=y+x; if s==2 p=2 else p=s-10 end Quote
todd Posted May 24, 2005 Report Posted May 24, 2005 Here are some ideas: 1. Use MATLAB in batch mode. 2. Copy all your m-files into a single MATLAB Script Node. Add top level m-code to selectively run the subs. 3. Roll your own using ActiveX. Quote
