GOOP - Tool to copy classes
Jim describes the OpenG resource "Rename Folder of VIs..." as a workhorse and it is true, I use it all the time. However, I typically use it to use an existing GOOP class or project as a template for another. As a result, I always have to first copy the source in Explorer and then rename. I modified the original routine to incorporate this step. Just drop the library in the ../LabVIEW 7.0/wizard directory and restart LabVIEW. (I can save down to LV 6.1 if needed, but not lower since I switched to an event structure to handle the UI.
Brian
Download File:post-987-1117024952.llb
